Hydraulic power units
Power units are redesigned with fixed-displacement pumps that offer energy savings up to 80% and noise reduction by up to 15 dBa. U-shaped tank with motor-pump group mounts on anti-vibration pads to insulate source of noise. All components are accessible and allow easy mounting of accumulator station or valve blocks. Suction and return lines are wide apart for good separation of air in oil. Stainless-steel version allows use of any media, including water-based fluids.
Bosch Rexroth Corp., (610) 694-8298, www.boschrexroth-us.com
