Electronic joysticks
JED electronic joysticks are dual-axis controls that drive mobile proportional and directional valves. They have direct-to-valve outputs with no external signal conditioning or amplifier boards and run on 9 to 32 Vdc. They come with output configurations for voltage-controlled, PWM, or on/off valves and 0.5 to 4.5 Vdc output and are user-configurable for deadband and minimum and maximum output signal for seamless integration into mobile equipment.
Modular Remotes, www.modularremotes.com, info@modularremotes.com
