SVCL and SPCL valves provide integral piloting or load-signaling for directional control and load-holding. They are rated for system pressures to 3625 psi, holding pressures to 5000 psi, and flow rates to 15 gpm. SVCL10-30 low leakage, on/off solenoid operated poppet valves feature an integral load-sensing check valve. SPCL10-30 electricallyproportional, low-leakage poppet valves come with integral loadsensing check valve capability. SPCL10-32 electrically-proportional, low-leakage valves have an integral piloting port.
HydraForce Inc., (847) 793-2300, www.hydraforce.com
