Advertisement
R-and PR-6000 pressure regulators mount directly on pneumatic circuit boards or manifold subplates. Two models are available — adjustable precision with 20-turn adjustment range from 0.5 to 100 psi, and preset precision pressure regulator produces output of 0.5 to 40 psi from 100 psi supply. Maximum pressure is 150 psi. Filters are rated for 5 m.
Air Logic, (262) 639-9035, www.air-logic.com
