AEHD series of heated desiccant compressed air dryers perform to CAGI ADF 200 specifications while consuming low amounts of energy. Fully automatic, PLC-controlled and selfcontained dryers use a fail-safe design and offer flow rates from 150 to 3000 scfm. They combine high moisture capacity, premium grade, high crush strength activated alumina in optimally sized ASME code desiccant towers for low velocity and high contact time through the adsorbent beds.
Donaldson Company Inc., (800) 543-3634, www.donaldson.com
