Plastic air breather can be used on reservoirs from 5 to 105 gal. Visual indicator has a range of 0.5 psi and shows current contamination levels as a percentage. Replaceable filter element range is 3 μm absolute with a -in. threaded connection. When element is changed, push-button mechanism returns indicator to its original setting. Protective plastic insert prevents topping off of unfiltered operating fluid through the breather, which is compatible with commercial industrial hydraulic fluids.
Schroeder Industries, (724) 318-1100, www.schroederindustries.com
