Air dryer
Air dryer
Air dryerMini Dryer MD-35 fits equipment that requires small volumes of dry, compressed air. It performs in intermittent flow applications and is designed for air flows up to 35 scfm. It can be installed indoors or outdoors with only inlet and outlet air connections required and handles inlet air temperatures up to 120° F and supplies –40° F pressure dew point. Loose desiccant needs only periodic replacement.
Van Air Systems, (800) 840-9906, vanairsystems.com
