Air Filter Regulator
Type-300 Gulf Buster filter regulator features stainless steel trim and internal construction to stand up to salt water
environments. It comes with 14-in. NPT porting. Output ranges include 0-30, 0-60, and 0-100 psig. Maximum supply pressure is 250 psig. Standard mounting allows for pipe or through body. Temperature limits range from –20º to 180º F. Flow capacity is 20 scfm at 100 psig supply with 20 psig output. Exhaust capacity is 0.1 scfm with downstream 5 psig above set point.
ControlAir Inc., 603-886-9400, www.controlair.com
