Edited By Mary C. Gannon
NITRA AF series particulate and moisture separation air filters are available with 1/8 to 1 in. NPT female port sizes and either a semi-automatic or automatic drain. Polycarbonate bowls are standard on 1/8 to 1/2 in. sizes; 1/4 to 1/2 in. sizes feature metal bowl guards. The 3/4 and 1 in. sizes feature all-metal bowl construction with sight gauges. Replaceable 40 µm filter elements are standard. When stricter filtration is required, optional, user installable, filter elements are available. Mounting bracket for stand-alone applications and modular design enable easy field assembly for combining additional components.
AutomationDirect, (770) 889-2858, www.automationdirect.com/pneumatic-parts
