Precision regulator
Precision regulator
Precision regulator
Miniature precision regulator provides highly accurate air pressure control in limitedspace applications. This precision-machined regulator features an output pressure range to 100 psi, high-flow rate of 4.5 scfm, and a maximum supply pressure of 250 psi. Tight design tolerances minimize vibration, allowing the regulator to remain stable under changing operating conditions.
It is highly dependable and repeatedly returns to the set pressure when turned off and on. It offers repeatability of 0.16% and has a self-relieving function.
It operates in temperatures from –40° to 248°F. It offers low hysteresis. Mounting is via 10-32 UNF stud mount.
Pneumadyne Inc.
(763) 559-0177
http://bit.ly/HP811Pneumadyne
