Pneumatic slides
Ultra series slides are available with two cylinder options — M-series or ISO/VDMA 6432 — for long strokes. They come in eight bore sizes from 5/16 to 11/16; and 8 to 25 mm ISO. Alignment coupler isolates piston rod from side loading to extend life with 360° float. Square bearing block maximizes loading and lowers stick slip. Larger bores come with two rail blocks.
Numatics, (440) 934-3200, www.numatics.com
