ISO/VDMA cylinders' adjustable cushions reduce cycle times, noise, and vibration, and increase cylinder life. Ideal cushioning eliminates end-of-stroke bounce. They are available in bore sizes from 32 to 125 mm, with tie rod version to 320 mm. They are rated for pressures to 150 psi with temperature range of 5 to 158° F. A stainless-steel piston rod is standard.
Bosch Rexroth Corp., (859) 254-8031, www.boschrexroth-us.com
