CHE hydraulic cylinders are compact and flexible. They require less mounting space than tie rod cylinders, with many mounting configurations, porting options, and rod end styles. Corrosion-resistant aluminum body is available in 20 to 100 mm bore sizes and accepts sold state and reed switches that mount within the cylinder envelope, for mid-stroke or end-of-stroke piston position sensing. They are rated for pressur to 140 bar, depending on bore size.
Parker Hannifin Corp., US Industrial Cylinder Div., (847) 298-2400, www.parker.com/cylinder
