P5T2 short-stroke thruster comes in 12, 16, 20, 25, 32, 40, 50, 63, 80, and 100-mm bore sizes with strokes to 200 mm. Maximum operating pressure is 145 psi. It comes with standard through-hole mounting on all sizes and available rear mounting. Top porting is standard; rear and side porting is available. True rod-lock mechanism stops the unit in current position upon loss of air pressure.
Parker Hannifin Corp., Actuator Div., (330) 336-3511, www.parker.com/actuator/sys
