Guided air cylinders
LX series guided cylinders feature a onepiece extruded cylinder body with integrated guides. They are available with self-lubricating bronze or re-circulating ball bearings and a permanent magnet and built-in cushioning rings. Compact size is due to one-piece cylinder/guide design and a profile which allows for sensors to be installed directly into the sensor grooves. Standard bore sizes range from 20 to 63 mm for strokes up to 200 mm.
Airtec Pneumatics Inc., (630) 543-0265, www.airtec-usa.com
