Providing hydraulic power for Master and Commander: The Far Side of the World
Hydraulic Controls, Inc. of Walnut, California, recently provided all of the critical hydraulic components to power the key mechanical effects for the new film, Master and Commander: The Far Side of the World.
Master and Commander: The Far Side of the World opened in theaters around the world in November to universal critical praise. The film, which was primarily shot at Fox Studios in Baja, California, over 22 weeks in the summer of 2002, was one of the most difficult and expensive films ever made. This epic film tells the story of Captain Jack Aubrey and his crew of the HMS Surprise as they pursue, and are pursued by, an enemy ship.
In March 2002, Mike Rogers, sales/engineering manager of the Walnut branch office of Hydraulic Controls Inc. (HCI), was contacted by Dan Sudick, the special effects coordinator of the project for Fox Studios. HCI had worked with Dan previously on two other film projects. Dan asked if HCI could provide hydraulic components to power a gimbal (multi-axis motion platform) that would control a full-size replica of a 19th century naval frigate that would operate in a six-acre water tank with a crew of over 100 actors and cameramen on board.
To simulate the movement of a ship at sea (and in battle), the gimbal needed to provide various axes of motion - like heave, pitch and roll - while being constantly bombarded with hundreds of gallons of water from a wave machine and, at one point, 2,500 gal of water from a "dump tank".
Another requirement was that the system had to work reliably 12-14 hr/day over a five-month shooting schedule.
HCI, working with the Industrial Hydraulics business unit of Bosch Rexroth Corporation in Bethlehem, Pennsylvania, applied the latest hydraulic and electronic technology to make this difficult mechanical effect a reality.
The replica of the HMS Surprise that was used in the filming of Master and Commander was 179-ftlong with a design load of 200,000 lb. The ship was built on the set and mounted on the gimbal, which was approximately 40-ft tall with a 40-ft base. It weighed 60 tons.
When HCI first approached Bosch Rexroth with this design challenge, HCI spoke with Greg Gleason in Bosch Rexroth's Entertainment Division. Gleason suggested that Paul Stavrou (manager of Bosch Rexroth's Technology Group) run computer simulations on Mike Rogers' initial system design using Rexroth's exclusive HYVOS software to see if the gimbal, in various load and motion profiles, would operate as desired. Rogers then refined his design based on the recommendations of Stavrou and the HYVOS program.
It was determined that there would be eight cylinders that controlled the gimbals' structure. Four 10-in. bore by 108-in. stroke for the heave axis (to lift the ship up and down), two 8-in. bore by 38-in. stroke for the pitch axis (to raise or lower the bow) and two 12-in. bore by 51-in. stroke for the roll axis (to roll the ship from port to starboard).
All of the cylinders operated under water, usually under turbulent flow conditions. Each had a cable-extension position transducer that accurately tracked the position of the cylinder.
The central hydraulic system which provided power to the cylinders on the gimbal consisted of two 750-hp diesel engines, each driving four Rexroth AA10VSO140 pumps. These systems produced up to 500 gpm at 3,000 psi to bring the gimbal's complex motions to life.
Bosch Rexroth designed and built four custom high-flow manifolds for the project (two manifolds for the heave axis and one each for the pitch and roll axis).
These manifolds were machined to mount a total of six Rexroth 4WRZ25 proportional valves, which were driven by Rexroth VT11011 analog driver modules. The manifolds also included Sun Hydraulics anti-cavitation valves and relief valve cartridges.
The plumbing from the HCI system to the gimbal was done through two headers (pressure and return) that were custom built in HCI's Walnut facility. Everything was tied together with hundreds of feet of 2" high pressure and return hose supplied by the Gates Corp.
In late May, the hydraulic components were assembled on the set and HCI's Rogers spent several weeks in Baja with Don Bogusky of Bosch Rexroth's Service Department helping Sudick set up the system so it performed safely and to the satisfaction of the film's director, Peter Weir.
The results were spectacular and are earning praise from critics and talk of an Oscar for Sudick and his crew. "Our Oscar was a comment from Dan that during five months of difficult shooting, not one minute was lost due to hydraulic problems. The system worked flawlessly," said Dave Madden, assistant general manager of HCI.
HCI is the largest hydraulic distributor in the Pacific Southwest with 11 full-service offices in four states. Past film projects include Titanic, Jurassic Park, Men in Black, The Perfect Storm, Spider-Man and the upcoming Spider-Man 2.
Information provided by:
610 Reyes Drive
Walnut, CA 91789
Phone 909-869-7600
Fax 909-869-7706
www.hydraulic-controls.com
