NFPA interchangeable air cylinders feature oversized nonmetallic, composite rod bearings for maximum load support, wear resistance, and high cycle life. Bore sizes range from 1.5 to 6 in., and strokes go to 48 in. Cylinder heads and caps are black-anodized aluminum, and standard cylinder barrels are hard-coated aluminum alloy. Optional composite barrels are high-strength, impact resistant, and self-lubricating with a low coefficient of friction.
Fabco-Air Inc.,
(352) 373-3578,
www.fabco-air.com
