Advertisement
Model IMH cylinders work in demanding applications. Available in bore sizes from 40 to 320 mm. All-steel construction with bolt-on mounts. Internally lubricated for life, floating, self-aligning, lubricated, repairable rod cartridge.
Peninsular Cylinder Co.,
(586) 775-7211,
www.peninsularcylinders.com
