P1M swing clamp cylinder’s stressproof steel bearing tolerates high torques. It is available in 32-, 40-, and 50-mm bore sizes in single-rod configurations with set stroke lengths of 10, 20, and 50 mm depending on bore size. Clamping direction can be right-hand clockwise or left-hand counterclockwise rotation. Clamp forces depend on operating air pressure from 27 lb for 32-mm bore at 29 psi to 371 lb for 50-mm bore at 145 psi. Maximum operating pressure is 10 bar.
Parker Hannifin Corp., Actuator Div., (866) 727-5228, www.parker.com/actuator
Circle 152
