Hydraulic cylinders
CDT1 and CDT4 NFPA tie-rod cylinders are available with fluorocarbon, NBR, PTFE, and wear-resistant polyurethane sealing systems. CDT4 operates at pressures to 3000 psi and CDT1 to 1500 psi. Reduced guide clearance provides uniform load distribution; spiral groove in rod bearing lubricates and compensates for pressure change. CDT1 features piston rod diameters from to 5 in.; CDT4 ranges from to 5 in. Bores range from 1 to 8 in.; strokes are available to 120 in.
Bosch Rexroth Corp., (610) 694-8298, www.boschrexroth-us.com
