Air cylinders
Air cylinders
Air cylindersMQ cylinder assemblies minimize sliding friction for breakaway pressure down to 0.001 MPa. MQQ comes in 10-, 16-, 20-, 25-, 30-, and 40-mm bores for pressures from 0.005 to 0.5 MPa and speeds from 0.3 to 500 mm/ sec. Strokes range from 10 to 100 mm. MQM offers speeds to 3 m/sec and comes in 10-, 16-, 20-, and 25-mm bores for pressures from 0.005 to 0.7 MPa. Strokes range from 15 to 100 mm. Miniature MQP offers pressures down to 0.001 MPa and comes in 4-, 6-, 10-, 16-, and 20-mm bore sizes. Stroke is 10 mm.
SMC Corp. of America, (714)-669-0941, www.smcusa.com
