DGSL series slides are designed for positioning or as an easy pick-and-place system. Integrated bearing system offers accuracy of 0.01 mm and linearity and parallelism in the 0.01 mm range. Eight sizes from 4 to 20 mm diameter offer strokes to 200 mm. Optional clamping unit and end-position interlock prevent undesired lowering of loads onto work piece carriers and provide protection in emergency stop situations. Three end stop systems are available — shock absorber, cushioned metal stops, or polymer stops.
Festo Corp., (800) 993-3786, www.festo.com/us/dgsl
