Four RTC-rodless thrust cylinders feature high load capacity. RTC-BV (Basic Version) is suitable for universal use, while RTC-CG (Compact Guide) offers high precision in compact size. RTC-EG (E-line Guide) is a guided version. RTC-HD (Heavy Duty) handles heavy loads. They are available in diameters of 16-80 mm and with maximum stroke length of 9900 mm, and are available with ISO-G or NPT ports. Oval-shaped piston gives them high load and moment capacity.
Bosch Rexroth Corp., (859) 259-3852, www.boschrexroth-us.com
