EFP MultiPosition and EFQ Multi- Force extruded, flat cylinders feature PTFE impregnated hard anodized bodies for high wear resistance and long seal life. They are interchangeable with cylinders of the same bore size and can connect and operate to an application’s pneumatic logic. EFP’s double-acting, single rod end design provides three positions. EFQ’s double-acting, single end rod design doubles resultant force on extension.
Bimba Mfg. (800) 323-5095
www.bimba.com
