Universal low-profile pneumatic cylinders offer direct interchange for most square-bodied, pancake-type cylinders. They come in 11 bore sizes from 8 to 100 mm, with 5-mm stroke increments. Metric ports and mounting are standard with optional imperial ports and mounting. Heavy duty, hollow or oversized rod, adjustable stroke, custom rod ends, multiple stage cylinders, and bearings, seals, and lubricants are optional.
Compact Automation Products, ITT Corp.
(864) 647-5454
www.compactautomation.com
