Pneumatic actuator
Pneumatic actuator
RT series pneumatic linear thruster carries high loads and provides precise load guiding. It is interchangeable with other major brands and can quickly and easily be reconfigured in the field. It comes in seven bore sizes from 916 through 3 in. and features composite bearings and recirculating ball bearings. It incorporates a Roundline Plus cylinder and an aluminum slide body for defined load guiding and maximum torque resistance.
Norgren
(866) 601-3615
www.trynorgren.com
