Air Cylinders
Edited by Mary C. Gannon
air cylinders
NITRA stainless-steel, round body, non-repairable pneumatic cylinders feature type 304 stainless-steel bodies with double rolled-in construction and high-strength aluminum alloy port ends. Single- and double-acting models are available with nose, pivot, and double-end mounting options. Some are available with magnetic pistons for position indication. Bore sizes range from 716 to 2 in.; depending on bore size, stroke lengths range from 12 to 18 in.
AutomationDirect
(800) 633-0405
www.automationdirect.com
