Edited By Mary C. Gannon
TDL2 and TDL4 metric two post direct lifters feature HP series metric air cylinders. Cylinders include adjustable cushion control, built-in lubrication system, and position sensing capability. Lifters feature linear bearings to deliver smooth, consistent lifting action. TDL2 is offered in bore sizes from 40-100 mm and in stroke lengths from 25 to 400 mm. TDL4 is equipped with a 40 mm bore air cylinder available in stroke lengths from 25 to 250 mm.
DADCO, (800) 323-2687, www.dadco.net
