T2 pressure transducer features a static full-scale accuracy of ±0.25% at 21°C. Digital temperature compensation ensures a total error band better than ±1% between –20º and 85ºC. Sensor design and conditioning electronics give it high stability and long life in the presence of overpressure, shock, vibration, and extreme pressure cycling. It can be configured with many process connections, output signals, and electrical termination options. It is available in ranges from vacuum through 0 to 20,000 psi.
Ashcroft Inc., (800) 328-8258, www.ashcroft.com
