HDM series mill-duty industrial hydraulic cylinder combines welded and bolted flange construction to minimize overall weight while providing high strength and serviceability. Pistons use non-metallic bearings that eliminate dynamic metalto- metal contact, increasing tolerance to fluid contamination. It comes in standard bores from 2 to 10 in., standard rod diameters from 1 to 7 in., with female NPT ports and threaded M/F rod ends. It is rated for pressures to 5000 psi and temperatures to 165°F. It offers six mounting styles and is compatible with petroleum base oils.
Hydra Technology Corp.
(800) 965-6250
http://bit.ly/HP611HydraTech
