Line of hydraulic swing clamps comes with corresponding valves and pumps. Single cylinder clamps provide 475 to 6000 lb clamping force from maximum pressure of 5000 psi. They actuate both the swing and clamping cycle in one continuous motion.
Pump provides peak 127 in.3 (0.54 gal) capacity and 75 in.3 (0.32 gal) usable capacity. It features a 1-hp motor (115/208- 230 Vac, 11.1 A) for producing 5000 psi. External pressure relief valve is adjustable from 500 to 5000 psi. Internal safety relief valve is set at 5000 psi.
Kurt Mfg. Co.
Industrial Products Div.
(877) 226-7823
http://bit.ly/HP1011Kurt
