Locking cylinders
Series CCA advanced locking cylinders with integral Amlock Rod Clamp controls over travel, drifting, bouncing, and reverse traveling. Cylinder has pressure rating of 250 psi, with the lock releasing at 60 psi. Standard bore sizes of 1 1 /2 to 8 in., and standard stroke up to 10 ft. Holds rod in any mid-stroke position. Spring force clamping eliminates drifting.
Advanced Machine & Engineering Co.,
(815) 962-6076,
www.ame.com
