Threadless connector system
Snap-to-connect (STC) system
Snap-to-connect (STC) system incorporates a latch ring for positive engagement of mating connectors and an elastomeric seal to prevent leakage. Connections from 3/5 to 1 in. with working pressures to 5000 psi. Featuring quick, easy connections, STC allows hose assemblies to rotate during installation to reduce hose twist and impact on hose life.
Eaton Hydraulics, (800) 547-7805, www.hydraulics.eaton.com
