Easy-to-connect fittings
Global Connect push-to-connect fittings feature grab-ring construction in a full range of inch and metric sizes. They feature thermoplastic bodies and nickel-plated threads. Working pressure range is 150 psi at temperatures of 0° to 140° F. Thread types include SAE, metric, BSPT, and BSPP, with pre-applied lubricant on male pipe threads.
Parker Hannifin Corp., Brass Products Div., (269) 694-9411, www.parker.com/brassprod
