RoFLEX 5000 series hydraulic screw couplings suit severe shear and breaker applications. They are connectable and disconnectable under pressure without need for bleeding and refilling hydraulic lines. Screw thread connections eliminate brinelling and seals are readily accessible for easy replacement. They come with caps and plugs to protect threads and help prevent the ingress of contaminants.
Holmbury Inc., (866) 465-6287, www.holmburyusa.com
