BarbMaster portable barbed fitting insertion tools feature an ergonomic design for industrial use. They can be used in a vise for table-top/shop applications. They handle most barbed fittings and hose combinations from 1/4- thru 3/4-in.
Aluminum alloy mounting platform has a low transfer rate and low particle generation properties; all mounting hardware and fasteners are stainless steel to reduce corrosion.
Benford Tools LLC, (817) 645-5320, www.BarbMaster.com
