Advertisement
Fire-rated coupling
HKFR fire-rated coupling is a quick disconnect coupling for high temperature applications where safety is a concern. It comes in three sizes — , , and 1 in. in steel; 1 in. version is also available in stainless steel. It is rated for pressures to 3000 psi ( and in. models) and 4000 psi (1 in. model). Designed for blow-out preventer applications, it exceeds all API and EUB compliance requirements.
Tuthill Coupling Group, (440) 826-1115, www.tuthill.com
