High-pressure hose, couplings
Spiral hose and couplings handle pressures to 6000 psi. A precision-machined internal ferrule crimps and tightly locks into any type of spiral hose for a secure, leak-proof, and corrosion-resistant fit. They eliminate leaks in hydraulic systems from fluid-bourne shock and vibration. They are available in 550 sizes and end configurations including JIC, O-ring, pipe, metric, and are designed for use with non-skive SAE 100 R12, R13, 4SH, and R15 hose.
Kurt Hydraulics, (866) 257-7995, www.kurthydraulics.com
