Pneumatic tubing, fittings
Nitra pneumatic tubing and fittings are available in polyurethane and nylon styles, from 532 to 12 in. or 4 to 12 mm. Tubing is available in 100 and 500 ft and is kink resistant, strong, and flexible. Nylon tubing suits high working pressures and provides heat/chemical resistance. Push-to-connect fittings include straight, elbow, tee and wye styles that withstand working pressures of -29.5 in. Hg to 150 psi and a working temperature of 32° to 140°F.
AutomationDirect
(800) 633-0405
www.automationdirect.com/pneumatic-parts
