Quick-release couplings
WF series guarantees direct and safe connections to internal threads for testing, and enables the correct connection of tools and attachments to the machine with minimal fluid loss. They are easy to use — simply push to connect. Visual safety indication alerts when coupling is correctly connected. Axial flow enables reduced pressure drop. Disconnection is performed in two steps to prevent accidental disconnection with automatic shutoff of the internal valve. They are available in sizes 3/8 to 1/2 and to 3/4 in.
Faster Inc., (800) 231-2501, www.fasterinc.com
