Pneu-Edge fittings feature consistently sharp, single-barb design which provides a tighter grip and seal than standard multiple barbs. Straight connectors, tees, elbows, crosses, and couplings available from 1/16 to 1/2 ID tube with threads of 10-32 UNF through 1/2 NPT and metric M3, M5, and M6. Materials include electroless nickel-plated brass, stainless steel, and aluminum. Recommended for use with polyurethane tubing. Precision-machined barbs ensure permanent tubing installation without clamps.
Pneumadyne Inc., (763) 559-0177, www.pneumadyne.com
