Threadless connectors
Snap-to-Connect high pressure connectors eliminate leakage, improve accessibility and installation ergonomics, and reduce installation time and production bottlenecks. For systems with working pressures to 6000 psi in sizes 3/16 to 1 in. Latch ring positively engages male and female halves without assembly. Tested to SAE J1176 specifications. Pressure impulsing with side load for 1 million cycles at 133% DIN 2ST operating pressures. Vibration to 500 Hz.
Eaton Corp., (888) 858-5658, www.eaton.com
