Advertisement
Line of heat shrink caps are made from cross-linked polyolefin material and molded and expanded to allow them to recover to smaller size when heat is applied. Expanded version allows insertion of wires or cables, with cap shrinking to adhere to size and shape of inserted item. Adhesive forms permanent bond and prevents moisture from reaching wire or cables.
StockCap, (800) 797-7876, www.stockcap.com
