Full-power brake system with ABS provides short stopping distance, vehicle stability, and control during aggressive braking situations. It handles eight or less channels of HABS control. The system employs brakes, tandem modulating pedal valve, accumulator charging system, and dual accumulators. Speed sensors monitor wheels. Inputs and outputs protected against shorts or over-voltage with built-in diagnostics.
Mico Inc., (507) 625-6426, www.mico.com
