Grease dispensers
Brochure highlights Streamliner lubrication management products, including M (variable feed rate with electromechanical drive), V (variable feed rate with electrochemical drive), GL-P, and GL-M (both spring-loaded) lines. It offers a brief overview of each line, product photos, and specifications for pressures, temperatures, volume, accuracy, and power supply in chart format. It also lists proper greases and accessories.
Trico Mfg. Corp., (800) 558-7008, www.tricomfg.com
