Corrosion-resistant shock absorbers
Weartec Plus standard corrosion protection is available on industrial shock absorbers and feed controller threaded outer tubes for washdown and outdoor environments. Independent laboratory salt-spray testing shows that its corrosion protection is 30% higher than platinum, Armaloy, and nickel plate; 67% higher than hard chrome; and 150% higher than black oxide.
Ace Controls Inc., (800) 521-3320, www.acecontrols.com
