Particle Counter
CML2 and CML2W series portable particle counters are designed for use with LPA View software and a main electrical power supply (12 to 24 Vdc, 1 A maximum). They measure and quantify the numbers of solid contaminants in hydraulic, lubrication, and transmission applications and use mineral oil as operating fluid; CML2W also measures percent of water saturation in oil and temperature. They can be used to 400 bar/6000 psi and feature better than 3% accuracy.
MP Filtri USA,
(215) 529-1300,
www.mpfiltriusa.com
