ETP Express shaft locking bushings provide precise connection between keyless shafts and mounted components. Low total indicated runout of less than 0.0008 in. minimizes component runout on rotating shafts, reducing machine vibration and noise. They are designed with a doublewalled hardened steel sleeve and flange filled with a pressure medium to handle torque ranges from 39 to 12,538 lb-ft. Sizes range from 58 to 2 in. or 15 to 80 mm.
Zero-Max Inc., (800) 533-1731, www.zero-max.com
