Pro Test system tests pressure without tools and checks for leaks in multiple spots without shutting down equipment. It detects leaking seals in pumps and cylinders, line blockages, faulty valves, clogged filters, and worn pumps and motors. System features test point with spring-load check valve and microbore high-pressure hose that connects to pressure gauge. Hose assemblies are rated for minimum burst pressure of 27,000 psi. Nominal hose bore is 2 mm.
Tompkins Industries Inc.
(800) 255-1008
www.tompkinsind.com
