PML2-W in-line fluid contamination monitor uses particle counter calibrated with ISO11171 for accurate and repeatable measurement of water saturation. Also measures fluid temperature. Designed to work to 400 bar working pressure. Results can be converted to PPM if oil type saturation and/or temperature characteristics are known. Features remote display module, and is PC/PLC controlled.
MP Filtri USA Inc.,
(215) 529-1300,
www.mpfiltriusa.com
